mmgriffith365
Just came back from our first long (8 days) cruising gulf coast of Florida.Can't wait to go again!
Post by mmgriffith365 on Dec 30, 2013 21:03:14 GMT
Hi,
We have had the boat two years and just returned from eight days of cruising the gulf coast of Fl. We had to motor the last three hours (no wind) back to our home port. We were running at 2800 RPM. Two and half hours into the motor, the tachometer started to give crazy high and then no readings. The engine remained constant and showed no signs of a problem. has anyone experienced this? Is it strictly a gauge issue or should we be looking for something else? Our mechanic is on vacation and we don't want to use it and risk damage. Has anyone else had this experience? Thanks!
Post by MalcolmP on Dec 30, 2013 21:25:21 GMT
Post by svsecco on Dec 31, 2013 4:21:49 GMT
My 39DS exhibited the same symptoms. The wiring harness chafed through on the aft port engine mount. the dealer replaced the harness under warranty. the replacement was straightforward and did not appear to be too difficult. you might be able to splice the wires together if the damage is not too bad.
mmgriffith365
Post by mmgriffith365 on Dec 31, 2013 19:11:59 GMT
Thanks so much for the responses! We will follow your lead and look at wiring and connections.
