Post by inari36i on Mar 7, 2022 18:18:10 GMT
when adding an asymmetric genniker do I need to fit a higher sheeve box to clear the forstay.
Post by zaphod on Mar 7, 2022 20:14:55 GMT
If you are just going to hoist the sail old-school you can probably get away with the fractional halyard exit, but if you think you might want to use a furler or a sock you should consider moving your spin halyard to the masthead to give you more clearance from the forestay, as well as making the sail a bit bigger. I moved the halyard to the masthead on my 39i.
