Post by simonmf695 on Jan 25, 2022 15:03:28 GMT
just changed the one a MF 695, port side, outboard of the fridge the cable connecting it is somewhat short, so you'd be tempted to pull it just a little to get the slack out of the hole to ease the disconnect and new connection well, don't, there is a socket and plug in line with the power point dangling behind the facia a small amount of tension and it pulls apart then the female side falls down behind the main electric socket for the boat in the cockpit unscrew the vent below the electric socket and you can just about reach both parts, but how to get two hands in the push it back together again ?? with one hand you can gently put the two together, but more force is needed to properly click it home the connector has square shoulders, i set up two tie ons, one on each side and wound those up with some long nosed pliers all back together again but why a connector there
