Post by chinagirl on Dec 6, 2021 15:30:18 GMT
Hi all. I have a 41DS with a Yanmar 3JH5E diesel. I have a very slow (about 5ml per month) coolant leak into the sump space below the engine. Does anyone have any suggestions where this might be coming from? Thank you.
Post by Mistroma on Dec 6, 2021 19:34:29 GMT
I had a similar leak with my 4JH4AE and tracked it down to the alternator pivot arm. Yanmar put the bolt through a waterway and it is a really bad design. It leaks whenever you adjust the belt tension but is never obvious. I put some tissue under the point where the arm meets the engine and it soaked up the leak.
My solution was to remover the arm and bolt, push a rubber grommet over the bolt and squeeze it into the hole. It isn't perfect but usually seals completely when everything has been tightened. I sometimes paint some varnish around that area.
It usually doesn't leak again until the belt tension is adjusted.
I've no idea if the 3JH5E has a similar issue but it is worth checking around where the altenator tensioning arm meets the engine casting. The 3JH4E looks similar to my 4JH4AE.
Post by bereboot on Dec 7, 2021 6:53:40 GMT
I also had a very smaller leak Finally i found that it was the rubber joint of filling cap on the engine that was leaking.
mic98034
Jeanneau Model: 39i
Home Port: Puget Sound, WA
Post by mic98034 on Sept 5, 2023 23:53:16 GMT
I had a similar leak in 2022. I have a 2011 39i with a 3JH5E. The leak was coming from the rear cover on the heat exchanger. Since it was a slow leak I didn't get to it for a year. I bought new a seal thinking that would fix it. But when I removed the cover I discovered that the aluminum of the heat exchanger at the point of the leak had corroded enough that it would never seal, even with new seals. I theorize that the corrosion happened because 1) the previous owner had filled it with the old style "green" coolant, 2) I didn't fix it when I first noticed the leak and therefore coolant in the area of the seal corroded the seat of the seal to a point that it was not repairable. I had to install a new heat exchanger. $3000+ ouch!!! You've been warned.
