Post by phil765 on Nov 16, 2021 10:04:21 GMT
I'm getting water collecting in the mast, water is seeping out between the bottom of the mast and the base for days after heavy rain. I'm thinking there should be a drain hole in bottom of the base/step to drain into the grid structure which is blocked. I want to drill a drain hole somewhere close to bottom of the mast, is this ok to do? Trying to figure out where to drill: Is there somewhere I can see a picture/spec of the base/step? Is the base/step a solid or hollow male plug? do I need to drill above it? Thanks -Phil
