Beam Reach State of Mind
Jeanneau Model: 419
Yacht Name: Beam Reach State of Mind
Home Port: Red Bank, NJ
Post by Beam Reach State of Mind on Oct 30, 2021 21:07:05 GMT
From the previous owner I learned that the boxing around the mast post in the salon can be removed, because he told me he installed some equipment in there. What's the key to pulling that boxing off? Is it on the clips like the panels in the aft berths that can be removed to give engine access?
Post by sunrise4 on Oct 31, 2021 14:05:22 GMT
Hopefully yours is the same as mine... First you will need to remove the ceiling panel around it. It is held up by two velcro pads on the left and right of the post near the wall. Reach up into the gap between the panel and the wall and gently pull down to release the velcro grip.
The post cover is held in place by three sets of two clips at the bottom, middle, and top. Starting at the top place your hands on either side of the cover and press together to release the clips.
Cheers!
Jeanneau Model: 419
Post by Beam Reach State of Mind on Oct 31, 2021 18:23:10 GMT
Thanks! I'll try it next time I'm there. I thought it had to be something like that.
