Post by jonjenk on Sept 23, 2021 18:52:09 GMT
I wanted to add a propane grill to my NC1095. Based on my past experience with Magma grills (poor heat control, flare ups...) I decided to add a Weber Q. The Weber Q is well regarded on lots of boating sites. In order to fit the Weber Q to a Magma LeveLock rod holder mount I needed to design a mounting plate. I was able to get the plate laser cut online for only $65 in 10ga 304SS. The end result came out really well. I've attached the DXF file for the mounting plate if anyone else needs it. You should be able to get any online laser cutting place to produce one from the drawing. The whole thing is held together with 1/4" fasteners. Editor note: You can view the CAD - DXF file with a viewer such as: products.aspose.app/cad/viewer/dxf
Attachments:WeberQGrillMount.dxf (179.55 KB)
ea
Jeanneau Model: NC 895
Home Port: MIDLAND, ON
Country: CANADA
Post by ea on Sept 24, 2021 7:55:57 GMT
I wanted to add a propane grill to my NC1095. Based on my past experience with Magma grills (poor heat control, flare ups...) I decided to add a Weber Q. The Weber Q is well regarded on lots of boating sites. In order to fit the Weber Q to a Magma LeveLock rod holder mount I needed to design a mounting plate. I was able to get the plate laser cut online for only $65 in 10ga 304SS. The end result came out really well. I've attached the DXF file for the mounting plate if anyone else needs it. You should be able to get any online laser cutting place to produce one from the drawing. The whole thing is held together with 1/4" fasteners. Thank you
Post by robert1 on Dec 21, 2021 13:06:09 GMT
I have owned one of the original Q’s as shown in the pictures it has never let me down. This grill will also be easier to clean than the original cast iron grate. Webber makes the best for the price!
Post by ck on Jan 1, 2022 21:26:33 GMT
Where did you have it cut?
PS. Thanks for sharing!
Post by jonjenk on Jan 5, 2022 3:23:46 GMT
Where did you have it cut? PS. Thanks for sharing! I had mine cut by oshcut.com It was less than $100 in 304SS including shipping.
Post by drakesmith on Apr 17, 2022 16:24:36 GMT
jonjenk: Thanks for your great idea and for posting that .dxf file.
I just received the plate in the same gauge and material as yours from OSH Cut for $111.47 including shipping (not surprised the price has gone up).
The eight holes fit the Magma LeveLock perfectly, but there are no holes on the base of my Weber Q grill, so the four holes on the arms of the adapter do not line up with anything. Does your grill have mounting holes on its base?
Post by alexrom on May 1, 2022 1:36:50 GMT
