Post by zaphod on Mar 3, 2021 16:09:39 GMT
A discussion on another thread got me curious about what mast manufacturers Jeanneau chooses to equip their yachts. Do they change from generation to generation, or specific models?
Most of the Jeanneaus I looked at when I was shopping had Selden masts, yet other owners did not even know Jeanneaus came with Selden.
I am curious whether different masts are found on the same model boats, or whether each model has a specific mast.
So what mast does YOUR boat have? Model? Year? Classic or Furling?
Our 2011 39i has a Selden mast with a classic main.
Post by puravida35 on Mar 3, 2021 17:01:02 GMT
2016 SO439 Sparcraft Mast Furling
mdrsail
Jeanneau Model: 2008 39i
Yacht Name: Grace
Home Port: MDR
Post by mdrsail on Mar 3, 2021 17:12:32 GMT
My 2008 39i has a Selden mast with car track main. This brings up a question: Since the main (fully battened) stacks with these large cars, the head is really high and I have to stand on my tippy toes to reach it to attach the halyard. Would anyone here recommend putting a mast climbing step a couple of feet up from the bottom? This would require riveting through and I'm concerned about structural integrity and interference with the lines that pass inside the mast.
Post by zaphod on Mar 3, 2021 17:20:38 GMT
My 2008 39i has a Selden mast with car track main. This brings up a question: Since the main (fully battened) stacks with these large cars, the head is really high and I have to stand on my tippy toes to reach it to attach the halyard. Would anyone here recommend putting a mast climbing step a couple of feet up from the bottom? This would require riveting through and I'm concerned about structural integrity and interference with the lines that pass inside the mast. My 39i has 2 folding steps to allow me to reach the head. There is no concern about structural compromise. The main load on that part of the mast is compression.
Post by MalcolmP on Mar 3, 2021 17:51:16 GMT
My 2008 39i has a Selden mast with car track main. This brings up a question: Since the main (fully battened) stacks with these large cars, the head is really high and I have to stand on my tippy toes to reach it to attach the halyard. Would anyone here recommend putting a mast climbing step a couple of feet up from the bottom? This would require riveting through and I'm concerned about structural integrity and interference with the lines that pass inside the mast. My 39i has 2 folding steps to allow me to reach the head. There is no concern about structural compromise. The main load on that part of the mast is compression. Ditto, have the same here. I had my rigger fit this one www.baselinemarine.com/mw/mastwalker.html which is small and doesn't get in the way, only downside is that it is painful to stand on with bare feet. To answer the question too. 2008 39i with classic mast made by Seldén. Quite a lot of earlier Jeanneau's had Z-Spar as detailed here: www.jeanneau-owners.com/Manuals/zsparprofiles.html
Post by Charlie-Bravo on Mar 3, 2021 18:49:11 GMT
Sparcraft furling mast, Sun Odyssey 35 2006
I know you know from the other thread, but thought to add for 'fullness' of the thread. CB
Post by Tafika II on Mar 3, 2021 19:03:15 GMT
2008 SO42DS (French Built) - Selden with roller furling main...and folding mast steps, similar to what Malcolm noted, up to the 1st spreaders.
Post by bereboot on Mar 3, 2021 19:32:04 GMT
So39i 2008:selden mast, classic sail
Post by ianpowolny on Mar 3, 2021 20:19:13 GMT
2008 45DS Z-Spars
Post by element on Mar 3, 2021 21:36:28 GMT
39i Performance, build in France in 2007. Selden performance mast with dyform shrouds and adjustable backstay. Equipped with 3 maststeps as mentioned before.
Post by NZL50505 on Mar 4, 2021 3:09:09 GMT
2012 50DS Sparcraft In-mast furling
Post by rene460 on Mar 4, 2021 10:23:18 GMT
My SO30i which was built in 2009, it has a Selden Mast and classic main. No need for steps to reach the head board on the smaller boat.
I replaced the sails after a few years and included the Selden bat cars for the batten ends, which have worked really well.
Post by loredo on Mar 4, 2021 11:03:25 GMT
2006 SO49, Sparcraft furling main mast.
Loredo
Post by moonshadow on Mar 4, 2021 12:13:25 GMT
Z-Spars,(USSpars) on a 2014 SO469
bj
Jeanneau Model: SO 45.2
Yacht Name: Atair
Home Port: Stockholm
Post by bj on Mar 4, 2021 22:07:57 GMT
Sparcraft furling SO 45.2 1999
Post by dbostrom on Mar 4, 2021 23:09:09 GMT
2010 SO39ip, Selden loose foot etc. "classic."
Selden: call w/serial number, get exact parts needed. No hassles. Hats doffed to Selden record-keeping, service after sale.
(just replaced a fractured t-fitting on upper portion of outer shroud and obtaining parts with compact-strand rope already swaged etc. was the easiest phase of repair, a rarity and a blessing given the local schedule)
Post by apo on Mar 5, 2021 14:40:24 GMT
2020 SO410 Performance: Z spars with stack pack
Post by Evening Star on Mar 5, 2021 16:31:38 GMT
2019 SO479 Z-Spars Furling main
Post by Don Reaves on Mar 5, 2021 19:50:02 GMT
2004 SO35 - Sparcraft
Post by NZL50505 on Mar 5, 2021 21:25:23 GMT
There’s no obvious pattern here - boats of all eras seem to have Selden, Sparcraft and Z-Spars.
Post by zaphod on Mar 5, 2021 21:50:51 GMT
There’s no obvious pattern here - boats of all eras seem to have Selden, Sparcraft and Z-Spars. So far the only pattern is specific models. All of the "i" generation seem to be Selden. I wonder if they put the rigs for each production run out to tender, or whether different rig manufacturers work with the designers on particular models.
Post by no3l on Mar 5, 2021 22:27:59 GMT
Hi
SO36i, 2008 Selden Classic
Post by NZL50505 on Mar 8, 2021 10:26:20 GMT
The riggers I talk to think Selden generally regarded as superior to Sparcraft which might explain why used with the “i” models.
Post by zaphod on Mar 8, 2021 20:08:49 GMT
The riggers I talk to think Selden generally regarded as superior to Sparcraft which might explain why used with the “i” models. My rigger said the same thing. Selden certainly makes very nice masts. I am guessing SparCraft just sharpened their pencils and won the contract back for the next generation.
