mf755wahoo
Jeanneau Model: Merry Fisher 755
Yacht Name: Wahoo
Home Port: Falmouth
Post by mf755wahoo on Jan 1, 2021 18:07:12 GMT
HNY Everyone
We are in the throes of installing a Webasto Airtop 2000 into our 755.
We have identified the heater position to be in the Portside underfloor space adjacent to the central fuel and battery compartment. At the moment the central compartment is partitioned off by 20mm thick plywood partitioning, so we will be opening up a hole in the partition. Our thoughts were then to run the air ducting along the portside under the deck, with one outlet in the main cabin under the table area and then one into the forward cabin.
We had thought that the rest of the bilge area of the boat would be pretty accessible - but today we had a proper look and it seems like everywhere has been partitioned off, so getting access to run the ducting is going to be quite tricky.
Does anyone have any tips/tricks or alternative suggestions they can pass on?
Many thanks
Post by fritz on Jan 4, 2021 15:39:13 GMT
Pictures of the factory install of an EVO-40 on a 2020 NC 795. PDF
