Post by Capt’n Ron on Aug 27, 2020 3:34:51 GMT
Another great improvement idea provided by Fritz. He found these on Amazon, Hypersonic wiper sprayers
The factory sprayers put out a stream which doesn’t really help much, so Fritz found an fairly easy fix for $11.00 by swapping out the sprayer that puts out a wide spray covering the entire windshield. I installed them today which took about 30 minutes with the help from my wife. Tips: Having two people really helps The factory ones unscrew, so don’t mess with removing the chrome plate Remove the black washer from the factory sprayers and install on the new ones. You may want to put some duct tape over the raw fiberglass to keep from getting splinters. Its a tight space where the motor and sprayer nozzle is located so be patient. I used a long needle nose plier to hold the new nut while my wife turn the nozzle from the top deck. After we got the nut started I applied went to the top deck and applied up-pressure on the sprayer to hold the nut in place as I tightened the sprayer. Worked great. You wont be disappointed with the results. Good luck.
Post by paint2424 on Sept 27, 2020 13:52:04 GMT
Hello Wondering where did you get the wide sprayer nozzle I don’t like the narrow spray pattern either
Post by Capt’n Ron on Sept 27, 2020 14:28:37 GMT
If you click on the “Hypersonic Wiper” in my post it should take you to the item on Amazon.
After some extensive use I can say it’s a definite improvement, but I did find when cruising at planing speed the airflow disrupts the fine spray to where it does not spray above the middle of the windshield. I didn’t find it to be too big of deal though.
