Post by jamestown on Dec 15, 2008 20:48:59 GMT
Does anyone know what the shroud tension should be on a SO 39i? Our boat is two seasons old and we seem to have more slack on the leeward shrouds when sailing and the forestay seems to sag more, so I am assuming the shrounds and stays have stretched a bit. What is the proper way to achieve the correct amount of tension? I have an old shroud tension guage from when I used to race other boats, but I don't know the correct specs for this boat.
Thanks.
Post by MartyB on Dec 15, 2008 23:45:32 GMT
Not sure that there will be a proper spec, unless the manufacture that builds and races typically will spec it.
I usually use about 20% of break strength per the Loos guage I use for my older Arcadia. Seems to work pretty well. If the winds are going to be up into the upper 20's and higher, I will sometimes tighten to 22-24%.
The thing I would like to figure out is the actual mast bend for different conditions.
Post by Trevor on Dec 18, 2008 21:06:53 GMT
