Post by ssisailor on Apr 5, 2020 12:24:57 GMT
Minor issue on my 2020 NC 895. While cruising my bow thruster will come on at random times. Curious if anyone else is experiencing same issue.
Mcaptain
Jeanneau Model: Jeanneau NC 895
Yacht Name: Dinner Out
Home Port: Milwaukee WI
Country: U.S.
Post by Mcaptain on Apr 6, 2020 20:21:38 GMT
Never happens on mine. I'm usually fumbling because I forget to turn it on until after I need to use it
Post by fritz on Apr 6, 2020 20:52:09 GMT
I was just exchanging emails with Quick USA regarding my NC 795 bow thruster. One of the things that stood out from that conversation, "I see that you have a boat from one brand of the Beneteau-Jeanneau Group which uses a customized version of our thruster." Paul Brown at Quick is very response just email him at techsupport@quickusa.com, assuming the 895 uses a Quick bow thruster.
I am curious about your wiring...
1. Do you have an ACR next to your Bow Thruster/battery? 2. Does the green light on the ACR come on when you are on shore power?
-Fritz
Post by CruisingCascadia on Apr 6, 2020 23:04:14 GMT
Yes, the light on the acr comes on steady while on shore power. If it is connected up properly. The acr on our 895 had the ground lead connected to the remote led light terminal so it wasn't charging. photos.app.goo.gl/Xtb821baApAa4dN56
Post by fritz on Apr 7, 2020 21:00:45 GMT
Yes, the light on the acr comes on steady while on shore power. If it is connected up properly. The acr on our 895 had the ground lead connected to the remote led light terminal so it wasn't charging. photos.app.goo.gl/Xtb821baApAa4dN56Same pieces and parts on my 795. Any chance you have a wiring diagram that shows the relays? Thanks.
Post by westboating on Apr 25, 2020 0:35:39 GMT
I'm taking my 2019 895 to the dealer next week to troubleshoot a thruster battery that wont charge. It's never that I know of activated autonomously.
Post by CruisingCascadia on Oct 15, 2020 21:43:20 GMT
Yes, the light on the acr comes on steady while on shore power. If it is connected up properly. The acr on our 895 had the ground lead connected to the remote led light terminal so it wasn't charging. photos.app.goo.gl/Xtb821baApAa4dN56Same pieces and parts on my 795. Any chance you have a wiring diagram that shows the relays? Thanks. No sorry I don't have one.
