Post by Zanshin on Oct 8, 2008 16:22:26 GMT
My bottom paint is wearing thin and I was thinking of having it redone. How many gallons is a realistic number for a 2 layer job with an additional 3rd layer along the water? I just got a quote that said 4 to 5 (which means 5) gallons would be needed. As they are charging $280/gallon that does make a difference. Is this a realistic amount for a 43 footer?
Post by Geoff on Oct 8, 2008 16:58:07 GMT
Hi
I have just used Seajet self polishing on my 36i and half a gallon dit it about one and a half times. I used a roller.
I guess that the same pot would do your size once fairly easily.
I have never put more than 2 coats on ANY boat.
Good luck.
Geoff.
Post by Zanshin on Oct 8, 2008 17:34:45 GMT
I've seen these guys do boats before and they do use a roller. This is a for a boat in the Caribbean and they will use Pettit black bottom paint. I had assumed that the yard might pad their hours and materials a bit, but if a gallon could do a full coat then they really are "putting it on a bit thick"!
--> Just checked the Seajet site and see that they state 10.75L for a 44 footer, which is about 3 gallons. That is for 2 full coats.
Post by Don Reaves on Oct 10, 2008 21:11:15 GMT
The coverage depends a lot on the type of paint. You can check the label (or internet) to see how many square feet one gallon will cover. As a rough estimate, you can figure the area you need to cover as waterline length * beam.
I have used a number of different paints over the years. My Catalina 30 used just under one gallon per coat of Micron CSC. My current SO35 uses just over a gallon of VC17.
Micron CSC requires quite a few coats because it wears off. But using too many coats of a hard paint can be really bad because it builds up and eventually starts peeling. Then you have to remove it all and start over.
Good luck. Don
Post by tomatillo on Oct 23, 2008 10:40:49 GMT
I painted my 43DS last season in Mexico using Petit Trinidad. I took her down to the gelcoat and put on three coats of primer. I then put two coats of Trinidad on the primer, with an extra coat on the waterline and the rudder. It took less than four gallons and I think it was an excellent coverage.
Post by tidetracker on Nov 3, 2008 14:38:32 GMT
My 43DS takes just under 2 gallons per coat.
One way to save some money: switch to Pettit Hydrocoat. This water-based ablative paint seems to work every bit as well as the far more expensive solvent-based paint, but at less than half the price... and it's far easier to clean up afterwards. I've been paying around $90/gallon for it, as opposed to over $200 for the competitive solvent-based paints, and it lasts just as long, and is just as effective.
You can apply it over previous coats of CSC or whatever. The only hitch: when you're about to launch, and the boat is hanging in the slings, you can't use it to paint the patches beneath the jackstand pads. For that, my marina supplies a bit of solven-based paint.
Post by Zanshin on Nov 6, 2008 20:05:50 GMT
thanks for that advice, I think I will see if budget marine has Pettit Hydrocoat
