Post by Zanshin on Jul 8, 2019 18:00:46 GMT
I punctured the headliner in my forward cabin. See below (I tried editing picture-in-picture zooming in to the cut, but I'm really no good with Photoshop) How can this be repaired?
Post by zaphod on Jul 10, 2019 15:18:55 GMT
Funny, I was looking at the headliner in my boat and thinking how delicate it felt, and what I would do if it got damaged.
If that panel is removable you could carefully stretch out the torn piece, and tape it from the back side, clean up the front side and tape it with clear tape.
Or, of you can find a matching material you can just glue a small patch over the hole.
Neither option is going to be invisible. The only way to make it like new I think would be to recover the whole panel, assuming you can find some material that is a close enough match to the rest of the panels in the area.
Personally, I think I would find a piece of matching material and patch it.
Post by Zanshin on Jul 10, 2019 16:08:14 GMT
It is a big panel, with lots of staples stretching the panel material to the plywood backing. If it had been smaller I would have tried removing the staples and vinyl to do a repair and then replace it. But I've never done this before and don't know if I could stretch the panel material correctly upon reassembly
Post by zaphod on Jul 10, 2019 19:53:30 GMT
In that case you have 2 options I think. You can either patch it using either clear tape, white tape, or glue a piece of matching material, or you can find a matching material and re-cover the entire panel.
I would patch it to start with, and if it really bothered me to have the patch I would plan to re cover the panel in future.
Post by MalcolmP on Jul 10, 2019 19:57:14 GMT
Maybe not the answer you are looking for, but when something like this happens to me, as it does, I try to think of a lateral option. Maybe you can cover it with a new item, with another on the equivalent opposite side? Maybe a light or fan or even some object d'art 😀 I think that is why many cars have odd stickers.....
Post by Don Reaves on Jul 10, 2019 22:57:57 GMT
Maybe not the answer you are looking for, but when something like this happens to me, as it does, I try to think of a lateral option. Maybe you can cover it with a new item, with another on the equivalent opposite side? Maybe a light or fan or even some object d'art 😀 I think that is why many cars have odd stickers..... I was thinking the same thing. I have a nice framed photograph on my electrical panel where the GPS used to be.
Post by MartyB on Jul 11, 2019 3:32:17 GMT
I put a set of reflectors on an RV trailer I had, when a hole got poked into the aluminum siding on one side!
If that panel is anything like the panels on my boat, not too hard to remove and repair/replace the vinyl. You do need to find the equal to what you have. If it is not available any more, or you can not find a vendor.....off to other options as noted.
IF, you do replace the vinyl, try to find stainless staples vs std ones, the std ones rust easy enough in a boat!
Post by Syrah on Jul 11, 2019 4:26:41 GMT
I’ve never done any of this, but recently stumbled on a similar fix on YouTube that suggested it’s possible.
What about using something like “Tear-Aid” on the back
Then: Use a material like Permatex adhesive to fill the front
Then vinyl paint to blend in with existing color of headlining.
Perhaps you could find a motor trimmer that had the necessary skills.
Post by Zanshin on Jul 11, 2019 10:27:40 GMT
Thanks for the post - I saw that product and video as well, but it also entails removing the vinyl from the playwood backing. I've looked at it again and really don't want to remove the vinyl; this section is a big one that also contains a porthole cutout, so it isn't just a matter of putting it back by stretching across 4 sides, but I have to get the porthole hole sorted out as well and that is not a job I'd like to do on my first ever attempt at headliner work. Perhaps I can cut out the section and put in another light That's better than a small sticker to cover up the blemish.
Post by pdodds on Jul 11, 2019 11:37:25 GMT
Have you thought about using a little 5200, 4200 or a white caulking? First apply some on the back of the torn area and stretch it back into position as best as possible, tape it in place and let it set. Once set, take a little more on the end of a toothpick to fill where the tear line is and using a wet finger, mold it into place. Using as little product possible to cover the scar is the key to a clean repair that does not draw your eye to it. You can always try one of the other techniques after, if you aren’t happy with your result.
