speedbird1
Jeanneau Model: SO 45 DS
Yacht Name: Cloud 9
Home Port: Sant Carles de la Rapita
Country: Spain
Shunts
Apr 7, 2019 9:36:13 GMT
Post by speedbird1 on Apr 7, 2019 9:36:13 GMT
I am sure this has been posted before but I can’t find it.
I have a 45DS. 2009. Recently the ammeter on the multi display is jumping about all over the place. Even with most of the electric equipment turned off the display shows a usage between 4 and 35 amps. I have cleaned the contacts on the shunt in the rear cabin near the batteries but cannot determine which of these lead into the back of the panel. All other functions appear normal. It may not be possible to extract the shunt leads for cleaning even if I knew which ones they are. I’m sure I’ve seen a photo on this forum but there are more leads going into the back of my panel than are shown in the photo.
Can an anyone suggest where I go from here?
Shunts
Apr 15, 2019 14:17:38 GMT
Post by Trevor on Apr 15, 2019 14:17:38 GMT
Hello speedbird1, Check out this hints and tips project as it outlines where the shunt cables attach to the multifunction panel. It is the black sheathed cable on the multiple pin plug. It is a different yacht but I believe the same multifunction panel. www.jeanneau-owners.com/hintsandtips/Inexpensivecurrentmeter.htmlRegards, Trevor
