Post by windspeak on Aug 7, 2018 21:48:26 GMT
High can anyone confirm tHe correct size for a replacement cuttless bearing for my 2002 so ds 43 the shaft is35 mm I have been over the side and measured The length at 140mm the outer brass casting Is proving a little more difficult to establish the size (murky water , bits of growth, and no glasses under my goggles) and measures 48mm the standard size available is. 35. 50 140 I would most grateful if someone could confirm the right size Jollybob presently in Grenada for Hurricane season
Post by markevans on Aug 14, 2018 15:44:00 GMT
We replaced the cutless bearing today on our 2003 43DS. It is 140mm x 50mm for 35mm shaft.
Post by andreshs1 on Aug 15, 2018 15:43:56 GMT
hi both
I am not planning to highjack the thread but talking about shaft leads me to sk about gearboxes. what engine and gearbox do you have? I am looking to get a flexofold prop but I want to triple check if the gearbox in my boat makes sense
Engine Yanmar 4JH3E Gear box. :Model ZF 30M. A 2.15. B 2.63. ZF Hurth Marine
cheers
Post by ales on Jun 6, 2022 10:26:53 GMT
Hi, I got several measurements regarding outside diameter of shaft bearing: 1.) 47,6mm SVB.de2.) 48 mm 3.) 50 mm Is it possible that for this model (SO43DS) there are so many versions? Tnx
Post by ales on Jun 30, 2022 10:12:28 GMT
I'll reply to myself: the right one is 47,6mm
