Post by ianr on May 22, 2018 18:12:14 GMT
Hi all, I have the standard Jeanneau fitted double light switches in my saloon cabin ceiling. I want to replace one or both swicthes with a dimmer - does anyone know the make of the current switch or or repalcement dimmer? Thanks, Ian
Post by MalcolmP on May 22, 2018 18:28:05 GMT
Post by MalcolmP on May 22, 2018 18:32:53 GMT
Not sure but many Jeanneau electric fittings are made by Berker www.berker.com/
Post by moonshadow on May 23, 2018 10:51:17 GMT
I am not a boat expert but recently completed changing most of my home lights to LED. Not all LEDs are dimmable so I suggest checking first on your lights and fixtures to see if they are dimmable before buying dimmers. I learned the hard way.
Post by ianr on May 26, 2018 23:16:08 GMT
Thanks for the feedback.
Post by MalcolmP on May 28, 2018 19:29:54 GMT
Do let the forum know if you find a neat solution if possible
Post by ianr on Jun 17, 2018 21:47:51 GMT
Post by MalcolmP on Jun 18, 2018 6:31:41 GMT
Great research, look forward to seeing the complete project
Post by ianr on Jul 2, 2018 19:16:21 GMT
I have bought a dimmer unit with cover and switch. I have tested that it worls with LEDs.
BTW Berker and Inprojal insert series are interchangeable. This unit was also advertised to be compatabilty and it is size-wise. Just need to decide how to wire and instal now. More later.
Post by ianr on Oct 15, 2018 18:56:30 GMT
finally got around to installing the dimmer..pleased to say it is all working.
I had to trim the mount a little. The wiring took a little working out..both the -12V wires have to go back to a -tive. I used the -tive terminal on the other led lamp in the same panel. All the LED lamps go back to a single fuse on the main board.
Post by MalcolmP on Oct 15, 2018 19:13:32 GMT
Looks excellent Ian. I will add it to Hints and Tips if you have no objection?
Thanks. Malcolm
Post by ianr on Oct 17, 2018 11:03:50 GMT
no objection.
Post by MalcolmP on Oct 17, 2018 18:40:21 GMT
