Deleted
Deleted Member
Post by Deleted on Mar 7, 2018 6:07:59 GMT
I’m about to exchange my old RC435 for an C80 chartplotter. Now I found out that the RC435 GPS antenna is of the coaxial type whilst the C80 uses one to be connected to NMEA or Seatalk. The GPS125 is not available anymore so I will have to buy a 2nd hand or an NMEA replacement version but does anybody know if there are converters on the market that convert the coaxial signal into NMEA. That would save me time to route the cable throughout the boat. Or is there somebody amongst us who has a GPS125 for sale.
Post by ianpowolny on Mar 7, 2018 20:20:13 GMT
Post by Mistroma on Mar 8, 2018 0:16:14 GMT
Pretty certain that the item you are talking about is just a GPS antenna (passive or possibly active). In that case, the actual GPS receiver is probably inside your old plotter and the antenna and co-ax are just supplying a decent strength signal. If this is correct you won't be able to convert to NMEA as there's nothing to convert. You need to get a unit with built-in GPS unit and might as well get something able to output NMEA.
I had the same battery problem on my 125 as already mentioned. The battery lasted about 6 years or so but was trivial to replace on my 2009 model as it wasn't soldered in place. I assume that models later than 2009 would also have easily replaceable batteries. So not a big deal if you do manage to find a relatively new 2nd hand unit.
Only 2nd hand Raystar 125 units I've seen recently have been in USA and seemed to be very expensive. I have seen units for ~£15 on eBay which look very similar to your original unit and have NMEA output. However, the output is via USB and would require an adapter to connect to a Raymarine plotter (not impossible).
Post by alenka on Mar 8, 2018 8:41:35 GMT
I think the 125 was replaced by the 130. It depends on if the GPS is integral in the C80 and therefore needs just an antenna, or if you need a separate GPS to determine the position and send that to the chart plotter. If you have not already come across this Raymarine page then it might prove useful. It lists the C80 at the bottom of the page. www.raymarine.com/view/?id=3528Edit. The above page has a link that takes you to another page that suggests the 125 in a Seatalk type 1 device which needs an adapter to make it work with the C80 which is a Seatalk type 2 device.
Deleted
Deleted Member
Post by Deleted on Mar 8, 2018 19:30:21 GMT
Ian, thanks for the link. Mistroma and Alenka are right, the antenne for the C80 is a system, the old antenne is just an antenna. The Galore replacement is an NMEA version but the original GPS125 for the C80 has the Seatalk interface. The problem I’m facing now is that I need the C80 NMEA input for the AIS data. So I either need an NMEA multiplexer or a replacement antenne for Seatalk.
Does anybody know if the NMEA input data on the C80 is directly distributed back over the NMEA out as I also need the AIS data on my COMAR NMEA2Wifi.
Post by ianpowolny on Mar 8, 2018 23:46:33 GMT
Marien,
We worked with the owner/director of the Raymarine base from Lisbon. He changed our system and connected the antenna in the auto pilot somehow. I don't know much more than that. Do you have an RM auto pilot? I'm on the boat next week so can take some photos to show how it's connected. Yours is an E system 2008 vintage so similar to the C.
Ian
Post by Trevor on Mar 9, 2018 0:36:00 GMT
Oh and also before I forget, Ebay has plenty of GPS125 antennae for you to choose from.
Deleted
Deleted Member
Post by Deleted on Mar 9, 2018 16:23:45 GMT
Thanks all for the feedback. I had some contact with Raymarine in The Netherlands but they told me the Smart pilot I have will not forward a GPS NMEA signal connected to the input of the Smartpilot. So I need a multiplexer.
Now I searched on eBay and found a great device. It is a NMEA2Wifi from Vela-Navega. It costs only € 45,- including shipping. The great thing is that it has 2 NMEA inputs and 1 output that multiplexes these 2 inputs. On top of that the Wifi is bi-directional.
So I solve 2 issues because I will replace my COMAR NMEA2Wifi with this one and will be able to control the pilot from the iPad as well. So no need to buy an old GPS125 but buy a cheap but good NMEA GPS antenna.
If there is anybody interested in a 2nd hand COMAR, please let me know.
Next thing I need is the NMEA cable for the C80. It is an expensive cable so I will probably buy an Amphenol connector and make the cable myself.
Deleted
Deleted Member
Post by Deleted on Mar 11, 2018 8:58:37 GMT
Is there anybody on the forum that has a brokken C70, 80 or 120 and doesn’t use the NMEA cable anymore. These plotters have a very rare NMEA connector which makes the cable very expensive. Otherwise I will try to find the right connector from Amphenol but that’s like seeking for a needle in a haystack.
Post by mickbond on Mar 12, 2018 14:48:51 GMT
Deleted
Deleted Member
Post by Deleted on Mar 12, 2018 17:23:18 GMT
Hi Mick,
Thanks for sharing this. I checked with Amphenol, Binder and Molex and later I came to Weipu but they all have slightly different dimensions. Furthermore those website don’t show the dimensions in detail. I will purchase this one as the mod indeed looks very simple. Again thanks a lot.
