Post by dendra on Dec 13, 2007 14:08:24 GMT
Dear sirs, there is someone that can help me?
I need to know the measure of the standard propeller (diameter and pitch) for the sailboat in the object.
I know for sure that the hub is for a 30 mm shaft line, is a 3blade (fix) propeller.
thanks in advance to everybody!
Davide
Post by MalcolmP on Dec 13, 2007 19:03:07 GMT
Dear sirs, there is someone that can help me? I need to know the measure of the standard propeller (diameter and pitch) for the sailboat in the object. I know for sure that the hub is for a 30 mm shaft line, is a 3blade (fix) propeller. thanks in advance to everybody! Davide Hi Davide Regret I don't have the exact info, but I will be changing the standard 3 blade to an autoprop when I get our new SO39i in the new year. I have the following data that we are specifying for the design of the Autoprop that may help 30mm shaft Tuff Torq gearbox Model KM35P Reduction ratio (fwd/asn) 2.36/3.16 Propeller speed(fwd/asn) 1231/921 Direction of rotation Clockwise (propeller shaft - fwd) viewed from stern The fixed blade prop is made by Radice, if you send them a request they made be able to help Their website is at www.elicheradice.it/Malcolm
Post by dendra on Dec 14, 2007 8:35:55 GMT
Hi Malcolm, thank' you a lot for your answer..... (before all, apologize me for my written english..i know, it's very poor.... ). Referring "Eliche Radice".....my job is to sell nautical equipment including propellers and my company, in Italy is the major customer of Radice (except shipyards) The problem is that only the shipyards know the propeller' s measure for each boat. I work everyday whit "Radice" crew and there is not possibility to find this kind of information....usually i find these infos directly from the shipyards but whit Jeanneau is not so easy thank' you for the infos about reduction ratio...whit this information I am able to imagine the correct pitch Any suggestion about how to contact directly Jeanneau???thank' you again Davide
Post by ianscott on Dec 15, 2007 14:57:08 GMT
Dear Davide The prop on the SO39i is described by Jeanneau as: 3-BLADED PROPELLER 17X13 RH30 The gearbox so far has been a TuffTorq KM35P with a reduction ratio of 2.36
I hope this helps, but if you need more info, let me know.
Ian Scott
Clarke & Carter Interyacht Ltd. Burnham Yacht Harbour Burnham on Crouch Essex CM0 8BL 01621-785600 ian@clarkeandcarter.co.uk
Importers of Jeanneau Yachts for the South East (UK)
Post by dendra on Dec 17, 2007 8:20:07 GMT
Thank' you a lot Ian Scott !!!!!!
that' s the info that i need!
