Post by vsergio on Apr 20, 2017 20:00:25 GMT
Is there any advantage of having a solid boom vang vs soft? Why the SO35 has is soft and for example SF35 is solid?
Post by dbostrom on Apr 20, 2017 20:36:15 GMT
No topping lift needed, hence one less thing to snag on the mail when raising, tacking etc. Anything that makes more roach possible must be good, right? Shamelessly copied from here (where there is an outcome story of a dropped boom):
Post by sitara on Apr 20, 2017 23:12:11 GMT
I sail with a soft vang, and have never had a hard one. My topping lift is cleated off at the mast and length adjusted so it does not flap around too much with the sail up and will hold the boom where I want it when the sail is down. The only drawback that I see is sail shape in light winds, but as I am only cruising it does not matter.
Post by Don Reaves on Apr 20, 2017 23:31:45 GMT
I have read that a number of manufacturers of hard vangs have suggested that you should have a topping lift anyway to take the load off the vang when the boat is at dock.
Post by dbostrom on Apr 21, 2017 1:14:20 GMT
The older we become, the more often the answer is, "it depends."
Post by petermc on Apr 21, 2017 2:58:16 GMT
I have a gas strut hard vang on my SF37, works brilliantly. We have no topping lift on it but do use the main halyard to support the boom and vang when not sailing.
Post by jdl01 on Apr 22, 2017 15:40:19 GMT
Light air main shape - twist - control is the principal performance benefit. Other stuff is mostly convenience related. Most builders recommend that the boom & main be otherwise supported when the boat is not in use.
Post by andreshs1 on Oct 15, 2017 15:33:48 GMT
HI there
I need to replace the gas strut on my new 1995 SO45.1, does anyone know what should be the resting inclination of the boom? 90°? Or higher?
Post by jdl01 on Oct 15, 2017 16:27:43 GMT
I have already replaced one gas cylinder on the selden rod kicker vang on our 379. Since then I have always raised my boom above 90 degrees when the boat is not in use. Taking some of the compression pressure off the vang seems to help keep the vang strength up and the replacement has now lasted twice as long as the original.
Post by andreshs1 on Oct 16, 2017 0:19:14 GMT
Hi
Ok, thanks It makes sense, I need to get the topping lift working
