Post by william51 on Nov 20, 2016 5:29:31 GMT
Hope someone can help. The neutral safety switch mounted in the side control is defective. I have removed fridge and checked around the area but cannot work out how to remove the unit, which would be withdrawn from inside the space it is mounted in. At the moment I can only think a way is cut hole in wood partition behind fridge which might give enough access to withdraw. Anyone who has replaced throttle/gear cables at sometime might be able to help. I would not think jeanneau would have holes made on a maintenance item. Thanks.
