Post by sabeiro on Dec 29, 2005 12:28:56 GMT
I would know some good idea about the tack point for the gennaker of a SO40 . The problem is the position of the pulpit and navigation lights. I´m thinking in a small bowspirit but i don´t know how to fix it thanks
marty
Post by marty on Jan 8, 2006 0:45:16 GMT
Have a look at a Dehler, they use a fixing system that can use a removable spinnaker pole as a bow spirit.
Martin SO40
Post by shaggyq on Jan 28, 2006 21:42:58 GMT
I simply drilled a hole through the anchor bowspirit and attached a swivel block. Then led a line back to the cockpit and fly the spinnaker above the pulpit. Works like a charm.
Post by sabeiro on Feb 21, 2006 17:14:10 GMT
thanks for your answer. Marty, I´m wating for the sun O 45 bowspirit. Shaggyq, I understand (in my very bad english) that you set the gennaker outside the pulpit, Don´t you have problems when you gybe with the pulpit? and sailing in a close angle with the navigation lights (to broke it)
