Post by peterherbert on Nov 13, 2006 16:55:43 GMT
Hi, has anyone anyfeed back from sailing the 39i, I have the deep keel, 2 cabin version and have sailed since July, after 3 years in an SO35. I am finding it almost imposable to get a good set with the Genoa! I have Tell tails Top Mid and Bottom, in 3 sets of 3, and No matter where I position the Cars or Halyard tension, I never get them to stream together, or in unison. Also seems to need enorous sheet tension. The pointing is not as High as the 35 as well! any Idea's ?
Post by badeandmel on Nov 16, 2006 5:27:19 GMT
It is hard to provide meaningfull comment without having a look at the set up - can you attach a photo of your jib trim and your rig set up and it would be easier to make informed comments.
The Quantum SO39i Genoa is a suprisingly nice sail (apart from the leach) so I do not reckon that this is your problem. Your issue is more likely with your rig set up. Are you comforatable that your rig is tuned properly? On my SO39i I have had to shorten the backstay as the factory length was too long which created too much forestay sag and too much rake. I would suggest you have a look at this. My D1s are almost as tight as they can get (bordering on needing shortening) with the D2s hand tight.
Overall with the rig set up, I have found the SO39i is very well balanced (you should be ablt to trim the sails on the breeze in 8-10 knots flat water and leave the helm and it should truck along nicely).
Post by peterherbert on Nov 27, 2006 10:47:48 GMT
Hi again
I took your advice and cranked on the back stays, D1 now very tight and the the Caps, D2,s just over hand tight .
The difference is really noticeable. conditions were not ideal for real testing, but the difference was seen immediately by the crew. thanks for your help. I will send Pictures of rig
Post by dublin on Dec 13, 2006 16:52:08 GMT
Do you have the polar diagram for the 39i I have one for the 39DS - same hull but less performance rig which suggests much quicker than the 35 The 39i with less windage and more performance rig should be even quicker
Post by dublin on Dec 13, 2006 16:54:14 GMT
Hey, Ignore last reply - sent to wrong box
