hpwhite
Prestige 36 - D6s (2006)
Post by hpwhite on Feb 2, 2015 16:37:50 GMT
Engines: Volvo D6s
Hi, I am due to chart some resonable distances this season and would appreciate some advice on the following:-
1) What would be the optimum cruising RPM to give the best fuel consuption? 2) What would be the average litres consumption P/Hr on the above recommended cruising speed for both D6 engines? 3) Is there a Max recommended running time at above cruising RPM?
Any other advice on distance pilotage would also be of great help, thank you.
Howard
nbrett
Waiting for Summer!
Post by nbrett on Feb 3, 2015 8:55:35 GMT
Hi Howard
I have a 2006 p36 with D6 310's.
We normally cruise at 2850 RPM getting us 24kts +/- tide. At this speed in a comfortable sea we burn around 80/90 LPH. that would give us 6/7 hours cruise or 170nm range with a really comfortable reserve assuming you have twin 400l tanks like mine.
The D6 310's are brilliant engines but as with all engines running them harder than recommended cruising RPM (85% WOT or 3000 RMP) will shorten their life and reduce your service interval.
With regards to the most efficient fuel consumption the prestige isn't a fully planing hull so it's a fairly linear burn vs speed all the way to WOT. However, if you are not in a rush, 1000 RPM will give you much better range at about 7 knts.
hope this helps
