Post by rxc on Mar 20, 2008 11:28:53 GMT
I still have the original 3-blade fixed prop on my SO43DS, and I need a prop zinc. Does anyone know the dimensions/size of this zine, and/or a source for it, other than Jeanneau? I am currently in the Bahamas, coming back to Florida where I will replace it.
The zinc on the shaft is still going strong, so I am not so concerned about loss of the prop zinc.
Ralph Caruso s/v Petillant SO43DS #266
Post by MalcolmP on Mar 20, 2008 20:30:52 GMT
I still have the original 3-blade fixed prop on my SO43DS, and I need a prop zinc. Does anyone know the dimensions/size of this zine, and/or a source for it, other than Jeanneau? I am currently in the Bahamas, coming back to Florida where I will replace it. Ralph I would double check, but try www.boatzincs.com/beneteau.htmlBoth Beneteau and Jeanneau usually fit Radice props as OEM, so if you can confirm the shaft dia. one of these should fit Malcolm
Post by rxc on Mar 21, 2008 12:13:02 GMT
Malcolm,
Thanks much for this site. It looks like it has what I need, both for the prop as well as for my Honda outboard. A good resource.
Ralph
