Post by jerrystroud on Nov 4, 2014 19:09:06 GMT
I need to replace a number of draw lick s which have jammed and the wordrobe lock. Does anyone were I can get these locks from ??
Post by ianpowolny on Nov 5, 2014 7:56:34 GMT
Do you have a picture of the draw locks? Need to see if they're the same as the sailboat ones. Are you based in the UK? Ian
Post by napoleon on Nov 9, 2014 17:20:17 GMT
I presume you are referring to the standard push button type of lock which has a plastic body and normally a brass push knob. If so these are readily available from most good chandlers as they are always jamming and need to be replaced. The UK chandlers "Force 4" carry a good stock with a variety of trim fittings.
For a stuck door a sharp blow on the door, in the vicinity of the lock, with the palm of the hand sometimes works.
Once freed they can be stripped and cleaned and then are best assembled with no lubricant - oil is what causes them to stick in the first place.
Good luck,
Napoleon
Post by jerrystroud on Nov 20, 2014 18:31:47 GMT
Thanks for that. I managed to source some via Sea Ventures from Jeanneau only couple of sqid each which was a surprise
