Post by artyman on Mar 15, 2008 16:24:28 GMT
Hi guys ;D I'm about to change the cutlass bearing and have manufactured a simple cutlass bearing removal jig. I have removed the grub screw on the side of the propellor housing no problem and removed the 2 folding blades no problem. How do I remove the prop?? Advice most welcome. Artyman Dorset UK
Post by MalcolmP on Mar 15, 2008 16:55:03 GMT
A standard 2 or 3 leg puller may work, but I would make life easier and borrow the yards hydraulic puller if you can - make sure you stand back though props tend to come off the keyway with a lot of force Malcolm
Post by MartyB on Mar 16, 2008 22:04:03 GMT
While you have a newer version of my Arcadia, same designer and hull from what I can tell, you may need to remove the rudder also, At least I did last summer!
