Post by pascale on Oct 9, 2014 15:20:38 GMT
HELLO, CAN ANYONE TELL ME THE SIZE OF THE SEACOCK FOR THE TOILET OF SUN ODYSSEY 49 2005. IS IT 2" OR 1.5" IN DIAMETER?
Post by windward54 on Oct 14, 2014 19:15:07 GMT
It is neither one. If it is the original seacock between the holding tank and the thru hull, it is most likely a 52 mm. If you are in the USA, you will have to order from Jeanneau America as metric fittings are hard to come by here. I ended up changing out the thru hull and replacing the seacock with a 2-inch for less money.
Post by pascale on Oct 16, 2014 2:23:44 GMT
Hello, thanks for your reply. I changed the seacock with a 2'' Randex valve. It works beautifully. I broke the handle of the valve for water and seawater under the sink. I have a lot of trouble finding the right 3 way valve. The boat is lying in Mauritius and I odtain most of my spare parts from France. Regards
