Post by davideso37 on Oct 17, 2013 3:21:42 GMT
I replaced seven bronze mushroom head skin fittings with flush fittings and after just a few races am very happy with the result.
The changes made this last winter include Winglets on the keel Flush skin fittings 300kg of lead glassed in behind the keel Removing all other excess weight and windage from the hull New carbon No 1 genoa DP GPL tri radial 60 mm extra luff round in the mainsail
Of all these changes only the skin fittings are a benefit each and every race and every leg of the race and I wonder why the manufacturers don't supply flush fittings as standard.
David
Post by MartyB on Oct 19, 2013 13:04:31 GMT
Cost! Or at least offer as part of the performance pkg, or extra or ?!?!?!?! Marty
Post by MalcolmP on Oct 24, 2013 16:22:19 GMT
Post by davideso37 on Oct 25, 2013 4:12:25 GMT
Malcolm,
I had read and noted that with interest. The local supplier of the flush fittings claims that some of the Beneteau owners are changing the skin fittings before launching.
When I looked around the local boat yard there was not a single racing yacht that had mushroom head fittings.
Our SO37 still has two fittings that are not flush and these are on the Raymarine Speed and temperature transducer and the Depth transducer housings. Call me obsessive but I will be looking for new flush housings for these for the next lift.
If you saw the interview with the C class cat winners on Sailing Anarchy you would have seen how obsessive they were about reducing drag since all that matters is the lift over drag ratio.
David
Post by MalcolmP on Oct 25, 2013 8:25:07 GMT
