Post by barbarakarsten on May 5, 2023 14:19:25 GMT
We have to replace our watermuffler (Exhaust) in our Jeanneau Sun Odyssey 43 DS, the shipyard has emptied the diesel tank and thinks they have to dismantle the galley now, can that really be? Can anyone tell us something about this? The diesel tank has to come out, that's clear, but how? The video is to big to load up
Post by andreshs1 on May 5, 2023 16:29:14 GMT
That is crazy!!!
I did mine last year, just to clean the tank you only need to remove the floor trim on bots sides and you will slide the tank out
basically, remove the 3 floor boards in the corridor, then you remove the trim on both sides, where the boards rest when closed. Then unbolt the tank and wiggle out gently
i removed mine alone, not heavy, just chunky
cheers
Post by barbarakarsten on May 5, 2023 17:36:25 GMT
Hi, does your tank go under the sink/galley? The mechanics says there is nothing that can be removed, the floorboards have been removed Greetings
Post by andreshs1 on May 5, 2023 17:40:25 GMT
Yes, these are standard boats, all made the same way
I'll be in the boat tomorrow, I'll send you detailed photos
Post by andreshs1 on May 5, 2023 17:42:44 GMT
By the way, just remembered, there was a write up by a member that dripped the kill for maintenance, that is where I got the details on how to remove the tank . It will be in that section where Malcolm keeps all the upgrades
Anyway, I'll send you photos tomorrow morning HKT
Post by barbarakarsten on May 5, 2023 17:48:36 GMT
That would be great if you could send photos. I've already searched, but I can't find the report cheers Ps i come from germany and my english is not so good
Post by andreshs1 on May 6, 2023 9:37:27 GMT
Attachment DeletedI there I am having issues uploading the files use this link> 1drv.ms/f/s!AoZeFtYsW1FthscHyrdQ6OWj1lT7oQ?e=KhWqts basically, once you remove the panels, just remove these 2 stripes, then unbolt the tank and disconnect all hoses, and you will be able to wiggle it out easily cheers
Post by barbarakarsten on May 6, 2023 9:44:25 GMT
This parts are allready removed, the spanish mechanic says he cant remove the tank
I have problems with the link, it doesn´t works
Post by barbarakarsten on May 6, 2023 9:46:29 GMT
wenn ich nur den Bericht von damals über den Ausbau des Panzers finden könnte...
Post by barbarakarsten on May 6, 2023 9:46:48 GMT
if only I could find the report from back then on the removal of the tank...
Post by andreshs1 on May 6, 2023 9:47:43 GMT
Send me a PM with your email But if that parts are removed, just removing the bolts that hold the tank down will be enough Just make sure he has emptied the tank 1st! Cheers
Post by barbarakarsten on May 8, 2023 7:14:44 GMT
Schicken Sie mir eine PN mit Ihrer E-Mail. Aber wenn diese Teile entfernt werden, reicht es aus, nur die Schrauben zu entfernen, die den Tank unten halten. Stellen Sie einfach sicher, dass er den Tank zuerst geleert hat! Beifall Thank you
Post by andreshs1 on May 8, 2023 16:43:43 GMT
Schicken Sie mir eine PN mit Ihrer E-Mail. Aber wenn diese Teile entfernt werden, reicht es aus, nur die Schrauben zu entfernen, die den Tank unten halten. Stellen Sie einfach sicher, dass er den Tank zuerst geleert hat! Beifall Thank youHope this helps www.jeanneau-owners.com/hintsandtips/KeelSO43DS.htmllook at the photo, the tanks slide out cheers
Post by barbarakarsten on May 10, 2023 7:21:07 GMT
I hope, that the spanish mechanics understand what to do ...
