Post by Quiddle on Sept 13, 2013 9:09:10 GMT
Has any one fitted or considered a mainsheet conversion on the 36i with an end to end sheet led back to both primary winches and cockpit clutches to lock off the genny & main. Are there any foreseeable problems with this other than extra lines on the sidedecks? All suggestions most welcome. Andy
Post by MalcolmP on Sept 13, 2013 19:42:41 GMT
Post by Quiddle on Sept 18, 2013 7:46:55 GMT
Thanks Malcolm. I should have thought to look in hints and tips first.
Post by MalcolmP on Sept 18, 2013 14:40:41 GMT
Hi Andy Not at all - you will probably have noted there is also a link www.jeanneau-owners.com/hintsandtips/36igermanmainsheet.html to some images of a 36i with the conversion, but personally I don't like how the sheets cross over the side-deck. I also think that full clutches are better than the jammers used. Malcolm
Post by j on Sept 18, 2013 20:40:55 GMT
See attached photo of a 36i in Sydney with extra cockpit winches for the german mainsheet Attachment Deleted
