Turning Freezer into Fridge
Mar 22, 2013 19:46:00 GMT
Post by Zanshin on Mar 22, 2013 19:46:00 GMT
(hopefully Mr. Kollmann could explain this issue)
I have a fridge and freezer unit from Vitrifrigo aboard the boat. Being in tropical waters, the freezer eats up a lot of energy and now I have eaten all the frozen steaks I'd purchased and have turned the unit off to conserver energy.
On my previous boat I had a switch in the freezer to allow it to function as a fridge. I sent an e-mail to Vitrifrigo asking about getting a different thermostat or if they had a suggestion as to what I should do. I got a response from customer service asking for the unit serial number and details and when I'd supplied that they stated that this conversion couldn't be done.
When I asked about details they wrote that it would cause too much condensation and that the cooling plate is overdimensioned and wouldn't correctly distribute the coolant and that the end result would be excessive energy use and lots of condensation.
While I believe the response I got, I have to admit that I don't understand it; I would have thought that running at a higher temperature in a unit designed for colder ones would save energy and be a simple matter of changing the thermostat temperature range.
I'd still like to optionally use my freezer for cooling beverages and would welcome suggestions.
p.s. I've appended the text from the last Vitrifrigo mail:
If you try to install a different thermostat, such as with a different setting for the fridge temperature , you head for some problem .
I try to explain the reason :
First of all probably , the system can’t cool the entire plate , because the compressor turn off to soon respect the timing of freezer thermostat .
That will result a lot of condensation, and the fridge will consume more, in order to switching on and off more frequently .
These are our advice because we want that the fridge works well
Differently from that point, you can try that, but I would like to inform you that ,with this ,the fridge will be out of warranty for the modification that we don’t authorize
The technical data of your thermostat now are :
At the maximum cut in at - 23 cut out - 28
At the minimum cut In at -12 cut out - 16.5
I remain at your disposal
