paulmtutt
Cassiopeia Jeanneau 439
Post by paulmtutt on Feb 23, 2013 10:55:57 GMT
I want to fit a 135% Genoa, as the winches are set well inboard it is difficult to see where the block between the Genoa track and the main winch should fit. Does anybody have a SO 439 with a 135% Genoa please?
Post by MartyB on Feb 24, 2013 2:51:04 GMT
If you can not find some one with a 135, your next step if you do not have the sail, would be trying to measure where the block should be. YOu can do this by eying a point half way up the luff, coming down thru what should be your clew, then where this line hits the deck, plus minus 12" or so will be where the genoa blocks should be. Plus in lighter wind days, minus in the heaviest days of that sails use, then the hitting the deck spot for probably 7-15 knot days.
