Post by panamech on Feb 21, 2013 16:21:08 GMT
Greetings, I am trying to change a faulty throttle cable on this 43 DS with the Goiot helm. The Pod (control head) on the right of the center cockpit helm is very corroded....If anyone can help me identify the shifter control and maybe a parts breakdown of this control would be appreciated. So far all the bolt heads have come off and the shoulders and threads are welded in place with corrosion.Also the actual halves of the Aluminum pod seem solid..You know where this is going....Thanks mucho PANAMECH[/
