Post by daveknight3 on Feb 6, 2013 17:25:36 GMT
My lift keel lower block (pulley) has failed. The boat is currently ashore and the keel is part way down if I get the boat lifted so that the keel extends to the fully down position will i be able to see the lower attachment point and replace all required. I have removed the upper access point and can see the upper block and rope attachment point however it is the lower attachment point that I am worried about, that and doing the job. Any help or advise would be most welcome.
Post by rene460 on Feb 7, 2013 9:12:41 GMT
Hi daveknight3, I have a drawing of the SO32 system (rev A 05/06/02). I assume it is the latest as I received it around 2008. You will know if it matches your view through the upper access hatch.
It is a more complex system than my 30i and not easy to describe, so I cannot answer your questions other than by the drawing. If you send me an email address in a PM I will send it to you, as I am sure it will help you plan the job. (Malcolm, I can send it to you as well if you like, but I found the instructions to upload too daunting! I would prefer using email)
Keel is 80 kg in air and I suggest will need to be let down, if not removed, so you need some jacking equipment and help. I would replace all components and ropes as they are all the same age and number of uses.
Other owners may be able to contribute more experience of SO32 Rene460
Post by MalcolmP on Feb 8, 2013 10:54:23 GMT
I have a drawing of the SO32 system (rev A 05/06/02). I assume it is the latest as I received it around 2008. Thanks for this rene460, Attached is the SO32 drawing for info Attachments:
