Post by Tafika II on Feb 2, 2013 1:20:47 GMT
The M14x1.5 oil plug/dip stick on my 2007 Yanmar 4JH4AE SER# E06649 needs to have a "T" fitting in order to attach a Jabsco 17820 oil changer. Has anyone done this and if so, what fitting(s) did you use to maintain the dip stick as usable? I don't care of the threads are metric or pipe thread, even if I have to use adaptors.
Post by Tafika II on Feb 2, 2013 19:58:04 GMT
OK, sometimes I make the solution too complicated. I took the hose with a 3/8ID from the oil changer and connected it to the dip stick tube after taking the dip stick out. Seals and works great...problem solved. Take one off the list and add two more on!!
