Post by so49curious on Jan 16, 2013 11:36:03 GMT
Learned Members! As mentioned in my last/first post, I am looking for a SO49. I found a couple (no teak decks - decided to get that put on in Phuket for under EUR10,000), but they both (2004 models) have in-mast furling mains Has any of you converted from in-mast to slab-reefing? If so, how did you proceed? Also, who can recommend which model of battcars? Many thanks! John
Post by Don Reaves on Jan 16, 2013 21:35:40 GMT
That would not be a conversion, really. You would have to replace the mast and sail.
If you haven't bought one yet, you should probably try to find one that's more to your liking.
Post by Zanshin on Jan 17, 2013 12:36:09 GMT
I think that the in-mast to slab-reef conversion can be done without replacing the mast. I would send an e-mail to z-Spar or Sparcraft (whomever makes the mast for that 49) to see what they recommend. But your mast will be thicker than necessary and I concur with Don that it would be wiser to find a model in the correct configuration.
OTOH - I like in-mast furling and would prefer that system. I believe that unless you are racing the boat and always have sufficient crew aboard you are better off with in-mast furling. I wouldn't dream of taking my 57 out alone with normal slab reefing, but usually end up doing day-sails and passages alone because of the ease of use of the in-mast furling.
Post by Don Reaves on Jan 18, 2013 3:10:59 GMT
I agree with Zanshin. My 35 is handful enough with a traditional main. Any bigger, and I would go for a furled main too.
Post by so49curious on Jan 18, 2013 9:08:23 GMT
Thanks for the feedback guys. Good comments and food for thought...
Post by Trevor on Jan 27, 2013 9:24:48 GMT
Hello John,
We had a traditional main on our last couple of yachts, an SO 36i and a Beneteau 373.
We now own a 42DS with a furling main. What a difference! Perhaps it is not about to win too many races but it goes very nicely for us and the difference in handling the yacht is beyond what I could have imagined. We love the furling main.
I have heard of some "go fast" sailors who have a conventional track attached to the mast to the side of the furling slot and use a conventional main when racing and then use the furling main when they are just out for a cruising sail.
That may seem a little extreme but allows the yacht to be used in both applications.
Happy sailing
