sihall
Jeanneau Model: 42CC
Yacht Name: Schona Mara
Home Port: Sant Carles De La Rapita
Country: Spain
Post by sihall on Dec 19, 2012 16:08:18 GMT
I am pretty sure this has been covered before however I would like to know how other people have fitted the galley screen. I have just had a quote for a screen at £200.00 and two brackets at £90.00 each, a total of £380.00. Are there any alternatives available or do I just bite the bullet and order? Thanks
Post by Zanshin on Dec 19, 2012 16:13:57 GMT
Who gave you that quote? Jeanneau or a glazier?
sihall
Country: Spain
Post by sihall on Dec 19, 2012 16:20:37 GMT
The quote was from Jeanneau.
Post by sitara on Dec 19, 2012 20:17:17 GMT
Hi Sihall, I made up a plexiglass splashback for my SO36i as the factory unit was far too expensive and also prone to shattering. The whole unit cost about $65 Australian dollars. Search for the thread "Re: Exploding galley splash back SO35" and there are some details and pics there.
This has been fitted to the boat for a couple of months now and no problems at all. It is probably a bit lower than the Jeanneau design but works fine. Now I don't get yelled at for splashing the furniture!
Rob
Post by sailbleu on Dec 20, 2012 7:22:34 GMT
Post by lateron on Dec 20, 2012 8:37:56 GMT
Hi Si.....it wasn't a Jeanneau but on my previous boat a Hunter Ranger I installed a plexi splashback without using brackets by having holes predrilled in the splashback and using stainless dome headed bolts through the wooden lip. The splashback rested on the worktop and I sealed any gap [ a very microscopic one] with bath sealant. After 5 years it still looked like new with no water ingress. If your wooden lip/fiddle is even only 5 cm this should work, the bolts were hardly noticeable. Saved a lot of money !!! Ron
