Post by because on Jul 17, 2012 1:56:40 GMT
I have a 2008 45DS. My starboard side 110v electrical is not working. The switch on the main panel doesn't trip, but I have no power to the microwave, outlets, etc. Can anyone tell me where else I can the circuits to see if anything else has tripped? Thanks.
Post by Don Reaves on Jul 17, 2012 9:44:25 GMT
Check all your ground-fault outlets. One may have tripped. I have one on each side of my SO 35, and when one trips, all the outlets on that side of the boat shut down, just as you described.
Post by MartyB on Jul 18, 2012 4:09:14 GMT
I'd go with a GFCI also, OR, the circuit breaker itself has fried! And you are not getting ANY power past it. The GFCI would be my bet over a bad breaker, wire or other issue.
marty
Post by rxc on Jul 18, 2012 16:10:54 GMT
I have the same experience. One of my GFCIs is a bit sensitive, and will sometimes trip when the power goes on. And, of course, the button is brown on brown, so you actually have to touch it to find out if it has tripped. Don't trust your eyes just looking at it.
