Post by corksailor on Jun 27, 2012 20:51:19 GMT
Having had trouble since March with power to the main panel eventually bit the bullet and replaced the entire and wiring loom £700. All fitted and alarms working Yahoo. Turned off motor and again no power.Called electrician back. There is a small connector panel on the Port side of the engine almost impossible to reach and there we found the faulty earth! Check this connector box first if you are having power problems in your control panel.
