Post by gre2 on Jun 8, 2012 10:18:17 GMT
At launch this spring, over a short period of time, the wheel steering seemed to develop more friction and in fact I think I damaged the motor on our Autohelm 4000. Is there a grease nipple or grease cup on the rudder post or how else to I lubricate the bearings?
Post by ianqv on Jun 9, 2012 13:26:38 GMT
I don't know if the actual rudder is able to be lubricated - perhaps someone else can confirm this? (I'm guessing no.... but hoping for a yes!! ) However.... I had the rest of the system apart last year to cure a sqeak / creak from the steering. If you take the top of the binnacle off you can see the chain, I used motorbike spray grease on it. Just spray on to the chain whilst moving the steering lock to lock. Then, go in to the aft berths and take down the wooden panels so you can gain access to the rest of the linkage. Once again I used motorbike chain spray grease. But on the plastic quadrant pins I just dropped in some 3 in 1 oil. Still having a slight squeak I then removed my steering wheel and lubed the plastic bearings behing it. You'll get change out of 1 hour start to finish (you may need a puller to remove the wheel). Hope this helps Ian
Post by gre2 on Jun 12, 2012 9:40:16 GMT
Thanks Ian, greased the top of the rudder post and also greased the upper end of the steering chain under the binnacle. Have not yet pulled the wheel off but still friction and cannot figure out why. Frustrating. Anyone else have some suggestions?
Post by MalcolmP on Jun 12, 2012 18:18:34 GMT
Thanks Ian, greased the top of the rudder post and also greased the upper end of the steering chain under the binnacle. Have not yet pulled the wheel off but still friction and cannot figure out why. Frustrating. Anyone else have some suggestions? Will take some time, but suggest you disconnect the cables entirely, then try the emergency tiller to test if the stiffness is from the rudder bearings. The emergency tiller is very short, so will not give much leverage, but you should be able to tell if the rudder is moving smoothly or not. Whilst the cables are disconnected you can also test each sheave pulley to ensure they are all working OK and take time to grease them (don't use WD40 as it just washes the grease out) If you also take the compass out (take care not to break the compass light wire in the process) you should then also be able to inspect the chain sprocket and confirm that the wheel itself is free to rotate smoothly M
Post by gre2 on Jun 15, 2012 18:56:21 GMT
Thanks "M" for the reply. Are you able to tell me whether there are bearings on both the top and the bottom of the rudder post. Also I was not able to find a grease cup or grease nipple so assume there is no way to grease the bearing unless I pull the rudder out completely.
Post by MalcolmP on Jun 16, 2012 8:04:09 GMT
Thanks "M" for the reply. Are you able to tell me whether there are bearings on both the top and the bottom of the rudder post. Also I was not able to find a grease cup or grease nipple so assume there is no way to grease the bearing unless I pull the rudder out completely. My knowledge on this is based on an SO34.2 but I suspect that is very similar to the SO37. Before looking at the rudder bearings I would thoroughly check that the problem is not with the wire and pulley system. How stiff is it? If the wire was very slack it is even possible it has jumped a sheave I am sure there will not be grease nipples and if you need to grease the bearing you should be able to drop the rudder a short distance (best out of the water) - remember the whole rudder is held by the upper clamp , but will also be retained by the quadrant. There will be upper and lower plain bearings Look at the drawings here: www.jeanneauparts.com/images/SO370/SU37000044a.gif(You can download all parts drawings at : www.jeanneauparts.com/en/index.phpbut they are very slow to download even with a fast connection and it looks like Max Marine are not taking orders) Here is the key to the drawing: No. SU37000044a Price ex VAT 1 INOX DECK FILLER € 42,90 2 EMERGENCY TILLER € 215,09 3a ST.ST. WHEEL D900 2Q1 QUILLARD Hull No: 1 -> 303 € 311,09 3b BARRE A ROUE D 900 IN.N.G.STDG 2Q1 QUILLARD Hull No: 304 -> 736 € 316,80 3c STEERING WHEEL D 900 COV.GOIOT 2Q1 QUILLARD Hull No: 737 -> € 418,50 4 SAFRAN SO37 GTE 2Q1 QUILLARD € 2.427,61 5 DROSSE / GOUVERNE SO37 2Q1 QUILLARD € 85,30 6a ENS.COLON. SO37 2Q1 QUILLARD Hull No: 1 -> 303 € 1.691,87 6b ENS.COLON. SO37 2001 2Q1 QUILLARD Hull No: 304 -> 825 € 1.556,51 6c ENS.COLON. SO37 M.C IN. 2Q1 QUILLARD Hull No: 826 -> € 1.282,04 7a PLEXI FOR CONSOLE SO421 2Q1 QUILLARD Hull No: 1 -> 75 € 63,26 7b CONSOLE 2Q1 QUILLARD Hull No: 1 -> 75 € 500,51 7c CONSOLE PR INSTR 6C SO37/43D 2Q1 QUILLARD Hull No: 76 -> € 169,21 8a LEVIER LAT.SIMPLE VOIL/CLOISON 2Q1 QUILLARD Hull No: 1 -> 275 € 25,69 8b SIMPLE LAT LEVER/SAILBOAT 2Q1 QUILLARD Hull No: 276 -> € 21,64 9a GOIOT QUADRANT 2Q1 QUILLARD Hull No: 1 -> 794 € 291,15 9b GOIOT QUADRANT 2Q1 QUILLARD Hull No: 795 -> € 291,15 11 RUDDER STOCK ST.ST. STOP 2Q1 QUILLARD € 95,88 12 ELASTOMER RING D115/75X10 2Q1 QUILLARD € 62,18 13 DELRIN RING D50 2Q1 QUILLARD € 93,28 14 O RING 3,53 X 49,21 2Q1 QUILLARD € 8,23 15 BUTEE SECTEUR SO400 2Q1 QUILLARD € 14,04 16 ADJUSTING RING 2Q1 QUILLARD € 19,81 17 RUDDER STOP 2Q1 QUILLARD € 12,12 18 STAINL.STEEL SHEER CONNEC 2Q1 QUILLARD € 19,81 Hope this helps
Post by gre2 on Jun 16, 2012 14:39:15 GMT
Thanks M at webcrew, I appreciate your help and will see what I can accomplish.
