Post by samwind on Apr 22, 2012 5:27:54 GMT
Hi, I purchased a Fantasia and doing an over overhaul. Now came the time to install the running rigging prior to replacing the mast. I lost all pictures at dismantling and would require help in:
- passing the rigging through mast head - same for reefing
Pictures, schematic or explanation are welcomec...
Post by MartyB on Apr 22, 2012 16:10:31 GMT
I believe Zspar is the mast maker, might look up that site, or USSpars in NAmerica. I tried looking up at two sites I know of with owners manuals for older boats, neither had an OM for a Fantasia. You might try looking here previousboats.jeanneau.com/2007/index.cfm?r=gamme&p=famille&id_type=1&ancien=1Voilier%20%28anciens%20mod%C3%A8les%29That is the main Jeanneau builder site with older models of boats. See if you can find a similar size, style to your fantasia, see if an OM is listed and sorta follow the rigging diagram for that boat. I will admit your fantasia looks similar to my Arcadia which there is an OM listed with how my rigging is run. Another site with some of the older OM's, tech specs and brochures is here www.jeanneauforum.nl/site/content/jeanneaudocumentatieRunning rigging there is nothing to specific to a given boat, as ALL boats will be run the same for the most part. marty
