aquaplane
Jeanneau Model: Espace 1000, 1982
Yacht Name: Seminole
Home Port: Tayvallich, Loch Sween.
Country: Scotland
Post by aquaplane on Apr 19, 2012 11:34:42 GMT
I'm looking for labels for a 1982 Espace fuse panel. The existing ones are about 12mm square and show white icons on a black background. I'd like to replace them with similar ones if I can.
I found a sheet of 60 text labels at an online chandlers for £10 but so many of those are no use I would rather print my own if I have to.
Has anyone sourced these recently?
Post by rxc on Apr 20, 2012 11:58:00 GMT
I had the same problems, and ended up printing labels on photo paper, and cutting them out with scissors to fit into the white outline on the panel. I used white letters on a black background, and double-sided sticky tape. You can't tell they aren't original. Make up a sheet of all the different labels you may want to have in the future, and print them on a 4x6 piece of photo paper.
aquaplane
Country: Scotland
Post by aquaplane on May 2, 2012 13:07:50 GMT
Thanks for that. I'll probably try to work something out with a Brother label printer I have access to if I can't get the original things.
Bob.
