Post by touchngo on Apr 18, 2012 9:11:00 GMT
Anyone with an SO40 able to confirm if the standing rigging dimensions for the stock zSpars Z601 section as specified in the Owners Manual (eg 2 x Cap Shrouds @ 8mm x 15.400 Mtrs) include the rigging screws or not?
My boats in Turkey and although I know that I have the stock mast etc... I have been unable to obtain the definitive measurements!
Appreciate any feedback others may have to offer.
Cheers, PT.
Post by touchngo on Apr 21, 2012 6:54:58 GMT
Just to answer my own question, got the attached from Jeanneau. It is for the 1998 spec'd boat, but was in response to my query with my 2001 Hull #. (For those who don't want to open a PDF document, the main details are as follows;) For the stock zSpars Z601 section, Code 973952 and Ref Z 10428; 2 x Cap Shrouds @ 8mm x 15.400 Mtrs 2 x Intermediates @ 7mm x 10.470 Mtrs 2 x Fwd Lowers @ 7mm x 5.480 Mtrs 2 x Aft Lowers @ 10mm x 5.540 Mtrs 1 x Forestay @ 10mm x 15.630 Mtrs 1 x Upper Backstay @ 8mm x 11.000 Mtrs 2 x Lower Backstay @ 7mm x 5.760 Mtrs These lengths include the Rigging Screws, set to 1/3rd of closed length (ie, you can tighten or loosen if necessary). Hope this is of help to someone (it was a right PITA to get this info when you can't just pop down to the boat and run a tape measure across things). Time will tell if I've cocked it all up! Cheers, PT. Attachments:
Post by so40gtb on Apr 24, 2012 2:04:35 GMT
PT,
Thanks for obtaining this. We're trying to get a deal done to acquire a 2000 SO40. These dimensions will be helpful as I prepare the spreadsheet to solve the rig tensions that can't be measured based on the ones that can.
--Karl
Post by touchngo on Apr 30, 2012 17:58:10 GMT
Knew it was too easy.
Apparently there are two clevis pin sizes that the standing rigging could be fitted with. Found a SO40 at QAB in Plymouth (Thank you Simon at Liberty Yachts). All Clevis pins are 12mm EXCEPT the aft lowers, which are 16mm (although the ones i measured were more like 14mm).
Hope it all fits!
PT
