Post by no3l on Mar 29, 2012 22:53:11 GMT
Hi All,
I need to replace the cutlass bearing on my SO36i: I intend to use a standard Jeanneau replacement which I understand is a "soft" rubber part.
Does the shaft have to be removed to do the work?
I would appreciate any inputs or comments from anyone who has done the replacement.
Thanks in advance Noel
Post by sitara on Apr 2, 2012 8:08:15 GMT
This has been covered in previous threads on cutlass bearing replacement. The cutlass bearing on my new SO36i is a rubber unit held in place with two nylon grub screws. On my old SO 29.2 I replaced the cutlass bearing (it appears identical to the bearing on the 36i). Process was to remove the prop, needed a prop puller to get it off, then undid the two grub screws and then using the rubber flange on the cutlass bearing I was able to wriggle it out of the P-bracket and slide it off the shaft. The new one slid in easily, grub screws replaced. In all about half an hours work - a very pleasant surprise as I was imagining all sorts of problems. Good luck and let us know how you get on.
Post by ianqv on Apr 2, 2012 18:38:43 GMT
