osi
SO 33i
Post by osi on Jan 11, 2012 15:46:14 GMT
Can I use 1500- 2000 or 2200 w catle or heater while connecting shorepower? i.e. no problem at cables for heating, etc. Jeanneau 33i - 2011
Post by ianqv on Jan 12, 2012 22:55:18 GMT
Hi,
Providing your shore power cable is man enough then yes running 2<3kw is fine.
I have a 2001 S/O 37 - I can run up to 9kw before things start to trip out!! - but I wouldn't advise going this far!!
Hope this helps
Ian
osi
SO 33i
Post by osi on Jan 19, 2012 23:43:38 GMT
Thanks Ian..
maby
SO33i Vixen
Post by maby on Jan 20, 2012 7:48:15 GMT
The connector normally used for shorepower is rated at 16A which translates to 4kw (in Europe, at least - half that in the States). You would expect any decent quality hook-up cable to be rated the same, so it is then down to the standard of the boat wiring.
Post by Don Reaves on Jan 20, 2012 11:36:14 GMT
The connectors commonly delivered with Jeanneaus in my area are rated for 30A.
maby
SO33i Vixen
Post by maby on Jan 20, 2012 16:42:15 GMT
The connectors commonly delivered with Jeanneaus in my area are rated for 30A. Which makse sense since you guys have half the volts, so need twice the amps for a given amount of grunt compared with us on this side of the pond!
Post by Don Reaves on Jan 20, 2012 22:07:39 GMT
You're right. I would love to be working with 220V, so I would have smaller wires to deal with.
maby
SO33i Vixen
Post by maby on Jan 23, 2012 18:46:17 GMT
You're right. I would love to be working with 220V, so I would have smaller wires to deal with. On the other hand, your 110 hurts a lot less when you accidentally touch it! :-)
