Post by rodgerg on Dec 9, 2011 18:39:56 GMT
Hello folks I have just been to have a look at my boat that was lifted out of the water a couple of days before yesterday's hurricane force winds. She is safe and sound however this is the first time I have seen her out of the water. There are 2 anodes on the shaft labelled 25 I assume that's the size? However I was surprised that there was no other anode on the hull is this normal? One other question, in the centre line there is a half oval shaped fitting with slots in the part further back. It must be under the engine area I think. It's not an echo sounder or log fitting. Anyone any ideas what this is? Thanks
lasse36ip
SO36iP - Henriikka
Post by lasse36ip on Dec 9, 2011 21:22:37 GMT
Hi, the shaft diameter is 25mm, so that is size as you already assumed. At least in my previous boat I got anode only on the shaft. In the spring I add the new one next to one old, and if those were working properly, in the autumn the old was vanished.
The half oval fitting is a scoop strainer of engine cooling.
PS. Glad to hear that the boat is safe, quite rough pictures seen from Scotland.
Post by j on Dec 9, 2011 22:08:01 GMT
One other question, in the centre line there is a half oval shaped fitting with slots in the part further back. It must be under the engine area I think. It's not an echo sounder or log fitting. Anyone any ideas what this is? Thanks Sounds like the engine water intake strainer, does it look something like this:
Post by rodgerg on Dec 10, 2011 15:15:11 GMT
Thank you both and what an idiot I feel not realising what the strainer was!!
