Post by corksailor on Sept 29, 2011 22:10:21 GMT
My 2003 Sun Odyssey35 is showing the layers of antifoul and patches underneath.Debating a sodablast but apparently have to re-epoxy after the job .Costs seem huge Any comments or has anybody had it done?
Post by sailbleu on Sept 30, 2011 2:51:26 GMT
I am currently removing all the AF on my 40DS with a scraper. I took the advantage of our Indian summer we are experiencing in Europe at the present to get the job done.
Sodablasting , sandblasting and so on are fairly expensive procedures , you probably need the wrap the boat in a tent to save the surroundings I presume.
My advise , dont use AF removers , they promise alot but deliver little. Been there done that. I started my project to end up re-epoxy the hull with a few coats and maybe copper coat everything at the end. I haven't decided yet because my previous rudder copper coat experiment has failed. I used a 1 on 1 ratio , meaning an equal amount epoxy resin and copper powder but the result after 4 months bathing is sad. The rudder was loaded with fouling. Perhaps the ratio was too low , or maybe it's due to the fact that I forgot to roughen up the surface of the rudder to expose the copper in the epoxy. Who will tell.
But this is getting off topic now . So buy the sandvik (bahco) scraper , lots of elbowgrease and you will manage to the clean the hull in one week.
Good luck
maby
SO33i Vixen
Post by maby on Sept 30, 2011 12:08:09 GMT
Was that with genuine Coppercoat, or were you mixing up your own equivalent from off-the-shelf materials?
Post by sailbleu on Sept 30, 2011 15:54:06 GMT
That was a home brew. But the copper powder (copperoxide) was the real stuuf I was told.
Deleted
Deleted Member
Post by Deleted on Sept 30, 2011 17:37:10 GMT
I just got done having all previous antifouling from my 03 SO35 removed down to the gel coat. It was done with a combination paint strippers and sanding. It was horrendously expensive due to the number of hours it took. I read an article in Practical Sailor, www.practical-sailor.com/issues/37_10/features/sodablasting_101_10610-1.html that quoted $1,600 US for soda blasting. Compare this to the $4,500 US I just paid to do the job by paint strippers and sanding, soda blasting seems like a bargain. Regardless you’ll need to reapply the epoxy barrier coat. However, since the SO 35 hulls are solid hand-laid glass hull that have vinylester resin in exterior lamination layers, a single epoxy coat would be fine.
Post by sailbleu on Oct 1, 2011 7:53:28 GMT
Hi James ,
I'm to about to drive off to the yard this morning it's 10:00AM now , and get the final patch done , the remaining 2 m² . To give you an idea , I started the scraping on monday , with an average of 4 to 5 hours hard labour (rest pauses included) each day . But within this timeframe I'm also talking about all the experiments (AF remover) , highpressure threatment and so on I performed. Leaves me after today a complete sanding of the hull so all the AF patches are gone and the gelcoat/gelshield is rough enough to receive the epoxy resin. Depending on my decision wether to coppercoat or not , I will apply at least 2 to 3 epoxy coats, wet in wet and finally get 2 coppercoats on top of the 2 previous layers , or a plain Hempel selfpolishing antifouling coat on top of 3 epoxy layers. I'm really not sure what direction to turn to at the present. I was hoping for some feedback from other boaters with the same issue. In fact , what are your intentions ?
Maybe this is worth a separate topic , meaning that I kind of approached my hull-cleaning project in a scientific way. I used different kind of procedures and took pictures to eventualy share it with a local sailor community since I have a interesting discussion going on a board in my own language. Maybe I'll translate the whole collection and put it on this board for the hints and tips section.
I'm not sure my hull is also a vinylester resin product , in all honesty I would think not. Although there is a grey gelshield coat (pansercoat of some sort) which I continiously compromise with the scraper.
Post by sailbleu on Oct 4, 2011 4:40:56 GMT
James ? Still alive ?? Regards
Deleted
Deleted Member
Post by Deleted on Oct 4, 2011 4:53:23 GMT
Hey Sailbleu: My yard recommended 3 coats of epoxy if the hull was not made with vinylester resin. Since mine was, we went with one coat as I mentioned. On top of that we had 2 coats of Pettit Trinidad SR which is a hard, high copper antifouling. We also put a third coat around the water line.
Is this what you wanted to know?
- James
Post by sailbleu on Oct 4, 2011 7:52:38 GMT
Hello James,
yes it is. I was hoping you would also go for coppercoat , that way I could get some feedback from other people so I can finally make up my mind on whether to coppercoat or not. My rudder experiment gave me mixed feelings you see.
maby
SO33i Vixen
Post by maby on Oct 4, 2011 16:49:03 GMT
That was a home brew. But the copper powder (copperoxide) was the real stuuf I was told. Regards I think the question is not so much the copper as the epoxy. The Coppercoat guys claim that they use a special epoxy mix that is designed to degrade slowly - standard epoxy is designed to protect the thing it's covering which, in the case of your ersatz Coppercoat, is the copper.
