Post by nornaj on Jul 15, 2011 23:25:32 GMT
Constant anchor use is resulting in nicks and gouges on the stem of the plumb bow of our SO39i. No matter how hard I try to avoid contact. Other manufacturers fit stainless steel protection to the stem (e.g. Dufour) or supply one as an option/extra (Beneteau). Anyone obtained one from Jenneau? Other manufacturer? Fitted one? Had one custom made? Advice and photos appreciated. NornaJ
Post by dublin on Jul 17, 2011 18:18:53 GMT
Go to thread on Delta Anchor and my post of 28 April showing flat wrap around bow fender which works very well o my 39ds
Post by nornaj on Jul 19, 2011 21:45:21 GMT
Certainly one way to go. Thank you. Meantime getting a quote on a custom steel bow plate. Will advise how it pans out. NornaJ
Post by flightdeck on Jul 20, 2011 0:23:38 GMT
Another good reason for having a Manson suprem or Rocna anchor, I use the boathook to catch the loop on the anchor and that way keep it away from the bow and if there is rubbish on the anchor you can "shake" it clean, Cheers
