Post by shootash on Jun 28, 2011 13:13:00 GMT
We had to have a new exhaust box fitted as we had electrolosys. Consequently a lot of water came in under the engine and storage boxes. This water is not running into the bilges and is beginning to smell. Any ideas on how to get it out
Post by venture on Jun 28, 2011 17:04:18 GMT
Had a similar problem with the exhaust on my 49SO, but no problem with trapped water. Could you try emptying the aft water tank, filling the forward tanks, and otherwise biasing weight forward (a lot of crew?) to get it to run to the bilge?
Post by Anwen (Deep Joy) on Jun 28, 2011 20:01:24 GMT
If you have one of those vacuum oil extractors, perhaps you could manoeuvre the tube into the space and suck the water out. If necessary, you could drill a 8mm hole to gain access for the tube without really weakening the structure of the boat.
paulreid
SO37 - Aquae Sulis
Post by paulreid on Jul 2, 2011 8:55:09 GMT
Disposable nappies/diapers/pampers?
